FahMon Messages - Help!
3 Apr 2007
Manchester
Hey all,
I'm completely new to F@H, I've just followed the quick guide in the sticky to get it up and running, I now have FAH_Core78.exe running as one of my processes.
However when I load FahMon I get the following message:
Code:
[21/05/07 - 09:46:13]   Reloading OcUK
[21/05/07 - 18:46:13]   Project number found for OcUK from FAHlog.txt: 3403
[21/05/07 - 18:46:13]   OcUK [ETA] | avg=N/A | last=N/A
[21/05/07 - 18:46:13]   OcUK has an unknown state (Unable to find a complete frame)
Have I done something wrong? Anything I can do to check its all running ok?
Username is OcUK_Inoshishi btw
You're currently running a project which Fahmon is not familiar with. Try using the menu option to 'Download New Projects'. This will give you up to date information on the various projects. You can also set a Preference to make this happen automatically.
ms9cw
I've tried that matey, seemed to download something but still giving off that error, however it does appear to be doing something as the log reads:
Code:
[17:46:16] Writing local files
[17:46:16] Completed 0 out of 4000000 steps  (0)
[18:11:33] Writing local files
[18:11:33] Completed 40000 out of 4000000 steps  (1)
Ah. You need to let it complete a couple of frames before you'll get any sort of PPD figure. Wait for one hour and check again.
ms9cw
Just to explain a little about what FahMon is doing here.
Basically when the FAH client starts a new WU (or picks up from one that was previously stopped), FahMon will wait until it sees at least 3 "Completed xxx of yyy" lines before it attempts to make any PPD or ETA predictions.
During this time, the client state will be orange, and the message log will state that it can't find a completed frame (because using FahMon's state logic it hasn't).
@UF - is it a bird, is it a plane, no is super Uncle!
He arrives in the middle of the night with a few expert words then disapears with only a calling card.
Will we ever know is identity?
Where did he gain is unkanny ability to seak out folder in diferculty?
Is he realy an uncle? how knows.......
....tune in next week for the all new adventures of Super Uncle
Classic :)
Stelly
