Failing Drive, advice please.
19 Oct 2010
North Staffs
My ole system is nigh on 10 years old and beginning to show its age. I switched on last evening to be met with a blue screen and it running a check on drive D: It eventually booted and I ran error check from within windows and then chkdsk and both confirmed I have some unreadable addresses.
C: = 250Gig Samsung SSD
D: = 1Tb Samsung HDD (partitioned D, E)
So fortunately the failing the drive is not the boot drive, it's a 1Tb that is partitioned D, files I don't use much: I have backups) & E: (windows backup/recovery files : Not backed up)
So what is the easiest most pain free way to replace it and not screw everything up. No doubt I have a few odds and sods/old apps on D: that I've forgotten about.
Is it as easy as remove the old drive and replace it? I'm thinking I may not bother partitioning it and leave it as a 1Tb D: this time.
Or is it bite the bullet and clean install?
Edit. System booted up this morning without issue.
Buy another drive that's at least as large
Install new drive alongside current drives
Install Macrium reflect (or create a bootable macrium reflect USB) and then clone the existing drive to the new drive, then shutdown and disconnect the old drive.
The new drive should then still have the existing D and E partitions, and everything should work correctly
Just as a thought. If I chose to install separate drives for D: E: instead of a single partitioned, drive can Macrium do that?
Yes I'm pretty sure you can copy individual partitions to new drives (and expand them to fill the new drive)
