- 2 Nov 2006
- Kent, UK
OK I have noticed in the last few weeks that my reasonbly new PC (build Nov 2018) has shown a tendancy to stick occasionally. It uses an M2 512 SSD for Windows and an HDD for data. The PC was working fine yesterday and this evening I turned the machine on and it looked like the whole of the HDD was gone.
So I ran Chksdk and it said it needed repairs but couldn't do them. So I rebooted the machine and then the files seemed to have returned and Chkdsk said the drive needed to be repaired. The drive is a Seagate Barracuda which is over five years old so now I am wondering if it is failing. If so what software should I run to check it? Normally if I suspect a failing drive I replace it. My logic is you can replace computer parts but never your data and that is more precious.
What is really annoying is that I am at the end of a job and need my files so I am worried about continuing to use the drive to finish the project even though it now says the drive is OK. And I do have a backup
This is a bit of a new/weirdone on me since I have never seen this behaviour before.
