SOLVED: I wanted to post this helpful link i found. af**** solved my fps problems and im not getting a constant 45-60FPS and NO ghosting or skips. Its amazing
http://forums.bethsoft.com/index.php?/topic/1123460-potential-fix-for-npc-slowdown/
(OLD POST)
Hi, ive just bought new vegas and im getting really bad fps problems on Ultra and high (medium is fine) in 70% of areas.
This is my spec
Amd phenom 2 x4 955 3.2 overclocked to 3.8Ghz
4Gb of ddr3 RAM
sapphire 5870 (playing at 1920x1200)
w7 64bit
The main problem i have is in gun fights. The fps drops to around 11Fps (fraps).
Roaming around it stays around 45 but often drops to 28-32fps for no reason.
Now ive been having a few problems with other games like WoW.
I used to play wow with two monitors. The first monitor for wow and the second to watch DVD's etc. In the last month I cant seem to do this anymore. The fps in wow drops from 60 to 22 where it used to only drop 5-6 fps while playing dvds in the background.
Ive also played a demo recently called Gothic 4 and the fps was more like a slide show.
Now i know the 5870 isnt the best card out there, but im pretty sure it should be getting better fps in fallout vegas on high at least. Ive seen people on here saying they get a good constant 60fps using the same processor and a 5850 on High.
Any one else getting this problem??
N.B
While typeing this, Something that hadnt occured to me is the Overclock. Im going to go set the cpu back to default see if that helps wow and Fallout vegas!
(OLD POST)
This is my spec
4Gb of ddr3 RAM
w7 64bit
N.B
