Fan advice
24 Dec 2011
Looking for 4 new fans for my build.
Need two for my H100 Radiator to run on a low quiet speed (visible so must look good)
Need two for my front intake (there visible so must look good too)
I thought about the corsair fans but aint sure which series i need?
And for front fans iv found some enermax cluster fans are they any good?
Radiators your need Static Pressure or (SP)
Airflow = (AF)
Though if you have Fan Filters & mesh infront of the Intakes you could argue Sp would be better to :)
personally i love Noctua but not everyone does :)
I have noctua 80mm's on the rear as i have a parvum :)
Front will be filtered only no mesh :)
So i need a dual SP Pack do i get the rings with these? Want red or white rings
The best configuration in my view would be:
2x Air flow fans at the front
2x Static Pressure fans for the radiator
I guess the AF fans depend on how much things are in the way on the inside of the case.
As a reference I got a dual pack SP series and they come with 3 sets of rings each. So 1 red, 1 blue and 1 white for each fan.
Lots of open space infront of intake as seen in my build log. Ordering the new fans and thermal compound tomorrow all being well as i need to re-seat my cpu cooler as my backplate orientation is incorrect :(
