First off sorry it too so long but i finally recieved the two nexus fans this morning after mayhem with the corier.
So, the 120mm fans. Using the tried and tested ear and hand method
(ear to test sound and hand to test airflow) shows that at 12v the akasa is the noisier of the two although not by much whatsoever but it does seem to push out a lot more air. At 5v the same is true and both fans are just about completly silent. The akasa pushing a little more air again. When I put the nexus in my case and put the side back on it was a LOT quieter at 12v than the akasa at the same voltage but it did cause my cpu to increase in temperature by about 3 degrees because of the decreased airflow through the heatspreader (the fan went on an evo 120 cpu cooler)
For the 92mm fans almost the exact same thing occurs, the akasa pushes more air out at both 5 and 12v and is ever so slightly noisier than the nexus.
One thing worth noting though is that the pitches of the two fans are slightly different. The akasa's have a higher pitch than the nexus' which could actually be the difference in noise i heard as the nexus didnt seem to whine as much.
I think for all round quiet computing the Akasa is a better bet as it is only slightly noisier than the nexus but is a lot cheaper and pushes more air. For a HTPC setting the nexus may be the better bet as long as the components are pretty cool running.This would mean you could probably get away with passive cooling for everything and a single 120mm nexus as a case fan and not be able to hear a thing
Hope this helps and isnt too late and helps you choose.
