Fan Control
14 Nov 2006
Newcastle, England
whats a good program to control 3 pin fans?
just got a noctua today and connected to the 3pin power fan on mobo
and its only running at 1000 rpm
how can i speed it up?
You can usually control the fan speed from the mobo? Have you got some kind of fan control option enabled in the bios? That may be slowing your fan down.
If not, Speedfan is quite a good piece of software that lets you control all sorts, and has auto options that work quite well.
