You can control outputs in any way you want in AquaComputer's stuff.
Individual control for every output with possible very different behaviour based on different data sources.
Or single control for all outputs, or at most with output modifier per channel like some channel.
You can also also calculate average from different temperatures like both CPU and GPU from software to use as control source.
Or add physical sensor measuring air temperature in case into mix.
You can also have different profiles, like quieter profile for web browsing/media playback and higher cooling profile or gaming.
There's no need to update instantly.
Once license is activated, both that date and expiration date are recorded.
And for as long as you're using that device, you'll get the last version released in that validity time freely, when ever you install AquaSuite again.
(unless adding newer/having device with inactivated license, or buying new "update" license)
