Can anyone verify if I am correct or incorrect? I'm under the impression aquaero 5 has single PWM channel and aquaero 6 has 2x PWM channels where each channel can have it's own temperature to PWM percentage curves to control fan speed .. and of course each curve can control several PWM fans. Not sure how many fans aquaero PWM signal is able to control, but normal PWM signals are usually good for 6-8x PWM fans, sometimes more before fans loops signal and either won't change speed or run full speed. I have ran 8x PWM fans on my aquareo 5 LT no problem.
All four channels of Aquaero 6 include PWM control option.
Max number of curve controllers is four.
But single controller can control multiple fan channels/outputs, including channels from connected AquaBus devices like Poweradjust or slave-mode Aquaero LTs.
(max number of channels controlled by single Aquaero is 12)
And sensors are other nice thing of Aquaero.
It comes with four physical sensors, having connectors for another four.
Maximum number of software based sensors is eight.
Aqua Computer Service background process itself includes Open Hardware Monitor and and can relay also readings from AIDA or HWinfo.
In case of OS/software crash there's adjustable "timeout" for how long Aquaero keeps software sensor reading locked to last reported.
After that software sensor reading resets to adjustable "fallback" value.
Then there's total of four "vitual" sensors combining up to three input sensor readings, either taking highest/lowest value from them, calculating average or difference. Possible source sensors include other virtual sensors.
So you can stick physical sensor to heatsink's base and use highest mode virtual sensor to combine software CPU temperature to backup from physical sensor.
After adding another sensor to measure case temperature near exhaust you can use average mode virtual sensor to combine that sensor reading to CPU virtual sensor reading for controlling case fans.
Some experience from PLCs isn't bad for figuring out "programming" of Aquaero...
Of course all output channels, sensors and controllers can be named freely so that you can keep up with them.
Just spend most of time from yesterday afternoon to today afternoon in swapping Seasonic X-650 to Prime Titanium 650 and switching control of fans from Aerocool FP-01 and Zalman MFC-2 to Aquaero 6 XT+Poweradjust.
Though still left Zalman into PC because of it having that power consumption measuring dongle.
