Fan controller for delta?
21 Oct 2009
Bedfordshire
Would this fan controller be ok for a delta 120mm fan? because im pretty sure I cant plug it straight into my motherboards fan header because it will blow it up.
The only connection on the fan is a 3 pin.
Will that fan controller be able to handle 24w, this is the specification:
Specifications: 120x120x38mm, -->190.00<-- CFM @ 4000 RPM, 59.0 dBA, 24.00 watts, 2.00 amps, 12v DC, 3+4 pin Molex connectors.
Thanks
Thanks, the fan controller wont be suitable, it can only take a maximum of 6v. Can you recommend anything else that would do the job?
