- 17 Jan 2014
So I have a H440 arriving tomorrow and only need to buy a few more bits before building the system. The System will be watercooled. I have the following Pump: http://www.overclockers.co.uk/showproduct.php?prodid=WC-416-EK&groupid=962&catid=2133&subcat=1845
My question is: With the H440 not having any optical drive bays, what are my options in terms of Fan Controllers? Does anyone know if the Fan Controller that comes with the Case will have the ability to change the fan speed?
Also, I'm guessing I'd need to buy a separate controller for the Pump? Any suggestions?
I don't have any fans either. I was going to test out the Case fans first and see how they do.
This is a bit of a learning curve for me so I apologise if this is simple stuff.
