Fan controller, is it possible to hook up 8 fans?
16 Dec 2008
Lincolnshire
I will be needing a fan controller and was wondering if it's possible to hook up 8 fans to a four fan controller, I will have 6 120mm xigmatek XLF-F1253, and 2 140 xigmatek XLF-F1453
Was looking at one of the Scythe Kaze-Master 5.25" Fan Controller.
Anyone know if this would run all 8 fans safely?
Not sure but does it say how many watts per channel it can handle?
edit...12w per channel
not sure of rating of fans but they will say an ampage on them so you can work out the watt (voltage x current in amps)
these are the listed specs of the fan controller
Dimensions: 148.5 x 42.5 x 63 mm
- Display Dimensions: 114 x 20 mm
- 5V or 12V (from PSU)
- Fan Adjustment Range 3.7 V (±10%) ~ 12 V (±10%)
- Four Fan Channels
- Maximum Ampere per Channel 1 Amp
- Fan Speed Range 0 ~ 9990 RPM (displayed in 30 RPM steps)
- Number of Temperature Channels 4
- Temperature Range 0 ~ 100°C / 32 ~ 199.9°F
- Measurement Frequency 2 Seconds
- Weight 162g
- Warranty 24 Months
and from the back of one of the fans (120mm) DC 12v 0.20A
is this enough info?
- Four Fan Channels
- Weight 162g
In bold, two fans in parallel if they're that rating is fine.
