Fan controller - Looking for replacement
7 Aug 2007
London
I have been out of the scene for a while so not up to speed with what's 'in' right now but wanted some advice on fan controllers.
I currently have a Scythe Kaze-Master, which I have had for the past 3-4 years, but is now playing up.
It basically doesn't let me properly control the fan speed on 2 of the controllers. Its either 'near full speed' or 'off', I have lost control in the mid range.
So looking for recommendations for a replacement.
Thanks
ive been looking at this sort of thing for my front panel and found the scythe kaze master pro km03-bk looks really nice
If you prefer touch screen then yes, personally prefer dials as its easier to make a fine adjustment
what he said ^^^ i prefer the roatary controls with a digital readout also dunno why just feels more substantial i think
After your comments and seeing some videos I think I will go for the lamptron fc5 v2...well try and get it when it comes in to stock :D
Thanks everyone
That looks great especially at that price but a couple of reviews say it's more a case of looks over functionality. Plus it will take 2 bays which I don't really want.
Also after thinking about it I'm really only looking for a simple, reliable fan controller on which I can check the RPM speeds at a glance for all fans.
So I have pre-ordered the Lamptron :D (Hope stock arrives soon as my sharkoon running at full speed (2k rpm) is doing my head in!)
Thanks anyway
