Fan controller - multiple fans / channel
Yes but you shouldn't go quite so close to the limit as that really. Maybe 80% of capacity would be acceptable.
Thanks Tealc. Just hypothetically of course :-)
Looking at a 10w/channel controller and just want to make sure it will run 2 x 120mm fans per channel.
Most fans are 0.2-0.3A so that's generally 3-4W each. Faster fans generally need more power so watch for that.
1400 rpm fan so yes it's entirely possible.
You'll certainly be ok for 2 per channel and probably will be for more than 4 with comfort. The more load the channel has though usually means the more heat that the fan control circuit will need to dissipate for that channel. So if you have 8 fans in total it's best to load them evenly across several channels rather than slapping all 8 on one channel and leaving the others empty.
