I replaced 2 case fans (got a pair of 120mm 3-pin BitFenix Spectre) intake and outtake. I noticed in the BIOS that they are not spinning the same speed as each other, I guess this is due to a power/priority issue? One is ~500rpm and the ~1000rpm - which is the max. It's not particularly loud but it is an uneven sound, if that makes sense.
Would it be worth getting a fan controller to set them both at say 750rpm and leave the CPU fan as it is? (just a stock one at present at around ~1300rpm) Or is there some other way to do it which I can't see in the BIOS?
Looking at this fan controller
