Fan controller
12 Dec 2005
I have a Enthoo pro case that has a PWM fan controller built in to it but I can't figure out how to individually change the speeds of the fans and not sure if it's even possible
Can anyone recommend a fan controller that will allow me to control 5 fans
I use a Lamptron FC6. Only 4 controllers but I've put 2 Akasa splitters on for the dual front fans and 240mm Rad fans.
What's your budget?
Do you want touch control or dials?
