Fan filter affect fan effectiveness?
filters will affect the the amount of air going through your system but if you have a problem with dust then this will have more of an affect on cooling.
Of course any kind impedance has effect to amount of airflow... amount of effect depending on density of filter (and amount of dust jammed in it) and pressure capability of fans. (forget pressure incapable Noctua S12)
But especially dense graphics card heatsinks suffer easily from dust and filters are lot easier to clean than heatsinks.
In case of that particular filter you could see can you cut away some of those plastic bars attached to X-shape main bars for lowering impedance.
Also what case you have, in thousand and one holes cheesegraters airflow is very uncontrolled meaning dust might leak past filters through all holes.
