- 10 May 2012
- North London
OK so I have a Lancool K62 Case , and I think maybe one of fans is on its way out as it's been squeaking here and there , all the fans in the case are the stock ones that came with it ....should i now expect in the next few months the other stock fans to start to " go " as well .
I do have some other fans, Aerocool Shark Blue Edition LED Fans...but they are pretty noisy lol
.....nothing in the way of the blades ....but when i took it out it did feel a bit loose ie "rocking " a little from side to side...also the screws were not all screwed in to the same depth...so i suppose it could well have been sitting in the case on a tilt , so i adjusted that , the other two stock fans i looked at feel pretty "stable"
, so i may have to invest in a set of new ones
