Fan help
6 Mar 2008
Stoke area
Hi all,
I've a couple of 8800GT's that I had second hand quite a while a go now and they've both had issues with fans. The working on has started sounding small generator banging away.
I've had it out, cleaned it but i think it must be bearings or something dying.
Question is, can I get replacement fans for these cards still or should I just save the £20-40 and get a newer cheap gfx card. I dont care about playing games at the top settings, as long as it looks good and is playable that's fine by me.
I do some video editing and a lot of photo/image editing, plus gaming.
Any suggestions or ideas?
If you don't care what the GPU looks like and want a fix on the cheap..
Then just tie wrap an old standard small PC case fan or a CPU heatsink fan to the GPU heatsink ...;)
(You most likely have some these fans laying around from old PC systems)
I don't care as long as it works and i need to strip it all down, clean it and rebuild it anyway with the extra cpu cooling i bought so could use the stock cooler off that if i can get a tight seal :D nice idea!
It'll do until I can afford a couple of hundred for a decent card :D
