Still mulling over what case to get, and after reading about the issues with the stacker 830, I think the TJ07 is a candidate.
A couple of questions though :
1. There is no intake fan, so how do your gpu's in sli get cooled. Do the top 120mm exhaust fans run quicker then the rear 92mm intake fans and create a slow negative pressure that pulls air in from the grille over the pci area ?
2. I am fitting a Arctic Cooling Freezer 7 Pro. Should I position it so the fan blows upwards towards the top 120mm exhaust fans ?
3. I read somewhere the 2nd revision of the TJ07 would address the issue of the hard to get off sidepanels and mislabeled hd and power cables. Does anyone know if this has been addressed yet ? I see OcUK were out of stock for ages so I can only guess they have the newer revisions in now.
Thanks
Thanks
</edit>
