- 3 Jun 2010
- Birmigham
I recently just purchased a Apevia Discovery PC Case and have noticed that the fans that come with the case have 4 pin molex connectors on them. Now as the mobo I have got is an Asus P5Q Pro Turbo I obviously need to either get a couple of 4 pin molex to 3 pin fan connectors or replace the fans.
Now recently I built my son-in-law a tower using Zalman Quiet Fans. These things come with Silicon Pins rather than screws to attach to the case and I can tell you that these fans are from from the word quiet. The only way they become quiet is by using the special connector that comes with them, which reduces the speed to half it's RPM. The so called special connection as a resistor on it and I believe it cuts the power down from 12v to 5v or something along them terms.
Now what I would like to know is can you actually buy these special connectors that come with the Zalman fans. Because I was thinking of using a 4 pin molex to a 3 pin fan connector and using one of these special connectors that reduces the fan voltage from 12v to 5v and I think very much by doing this I will have 2 quiet fans without replacing them.
