Fan noise
10 Feb 2011
Hi all I no the zotac amp extreme 2080ti is a very noisy card but what is the best fan profile to keep the noise to a minimum while gaming at 4k?. I say 4k as when in 1080p the fans dont spin at all and at 1440p the fans are abit nosier but at 4k its full blast.
I just wanted to no what is a safe fan profile at 4k to keep the noise to a minimum but not to damage the card. Using firestorm btw as the profiler.
I would aim to keep it around 70c for 24/7 usage. Adjust the fan profile to keep it around 70-75c but still quiet.
If noise is of a concern then you can undervolt the card also with MSI afterburner which should drop temps by a fair amount without reducing much performance (less than a few percent overall).
