Fan placement
18 Jun 2010
Hi, I have a Zalman z11 Plus case and I have 7 fans in total, 2 of which I added myself.
Theres 2 on top, 1 front, 1 back, 1 bottom, and 2 sides.
the PSU is drawing in air from the bottom if that makes a difference
Hwo should they be placed with regards to intake and expelling air?
thanks
What size fans where? I prefer front & bottom in. Back out and usually leave top to vent itself. If less then 50mm bottom clearance raise it up. Most case feet are too short.
All fans are 120 except the side 2 which are 90 i think.
dont use the side fans if you are gonna have 4 or more fans in the case.
Im not sure they are removable as they look built into the side panels
Leave side fans and top fans unplugged for now.
So you have 2x intake fans and 1x exhaust with top and sides as vents. 2x intake means air will be leaking out sides and top as well as being pulled out back... less dust in case.
I'll assume you are using a tower CPU cooler blowing front to back.
Now do you have 2 room thermometers? If so check that they read the same. Use one to know what ambient temp near intakes is and other to monitor top vent temp. Top vent should be 2-3c warmer then intake at front of top vent. Back of top vent and back exhaust fan will be warmer pulling air from CPU cooler.
