Hi guys,
Just finished building my first water cooling PC (pics to follow at somepoint), and I was wondering.
Currently I have 3x 120mm fans on the top 360mm rad, configured in a pull systen,m so they pull the air through the rad and then the fans themselfs and out the top of the case.
I did this so it is easier to clean the dust out, simply by brushing gently or blowing the dust and junk from the raid fins directly, rather then having to constently remove the fans to get directly to the rad.
Is this a prefered option, or should I swap the fans to a PUSH setup?
The fans are 120mm Corsair SP120 quiet PWM connected to a Lamptron FC5v3 fan controller.
Thanks in advance
Thanks in advance
