hi i have the 465x case and have all my fans plugged into the rgb hub 3 fans work but my h100i fans do not work with the rgb hub can any one help i do not have a commander pro
How many fans do you have? Corsair gear needs the fans plugged in in sequential order - if you have 5 fans, they must be plugged into ports 1, 2, 3, 4, 5 rather than 1, 2, 3, 5, 6 for instance.
Basically the data signal for ARGB fans is passed in series from fan to fan and the hub joins these outputs and inputs.
