- 3 Jun 2005
Thanks, very useful.
I would give the Gentle Typhoon the slight edge on the performance/noise ratio as far as heatsinks go/ probably becasue it can spin at higher rpms with low noise, which means high static pressure. However it is harder to find, un-braided cable, limited accesories and quite dear. I also think the Apache could be the better case fan, and it has PWM.
Extraordinarii I indeed yould like to see how sickleflows would compare, they have a well proven design that's for sure.
Maybe for the radiator testing...
