Fan screws help
31 Mar 2013
I am going to be adding more fans to my XSPC AX480 Quad Fan Radiator but i don't have any more of them long screws and i have been trying to find some but the only ones i can find are in the US. I did find some Rubber plugs/pins will they work? and can any one tell me where i can get some screws from as well.
ty for the help the only ones i can find on there that is the right size need a hexagon key thats ok but is there any others i can get or some thing to make it run more silent?
