Designing a radiaor fan shroud at the moment, but dont have all my fans yet. The fans will be inside the shroud to hide them away, so the case of the fan will have to fit inside. Are all fan cases the same size or do they vary?
Vary depending on what the case can fit most now fit 120mm x 120mm
I would just make a shroud with 120 fans
Yes, but that would be boring wouldn't it... I bet you've never swapped the stock fans out of your computer case either.
140mm shroud adaptor - go for it!!
