Hello
Just after some advice. I finally built my first pc with the following specs
Ryzen 5600 with stock cooler
6600 challenger
16 GB ram
Cool master q300l
So my temperatures at idle are 55c with fan speed of 52% ISH. When YouTubing etc it goes to 60c at 65%
When gaming it goes to 75-85c depending on which game and a fan speed of 100%.
I appreciate that the temperature will be higher with a stock cooler but because the parts are low to mid range I thought it would be sufficient. My concern is more the fan speed being at 100% all the time when gaming. Is this normal for the wraith cooler?
Regards
6600 challenger
16 GB ram
Cool master q300l
Regards
