fan spins for a second then stops
Have you cleared the CMOS?
24 pin and 4/8 pin power to mobo?
CPU connected to CPU fan header?
Thermal paste correctly applied?
Power to gpu if needed?
Have you run memtest to check your memory is ok?
plugged the mobo power in and the cpu power in? myself and quite a few people iv seen had this problem (silly i know but everyone misses something now and again).
the comp will start for a few seconds fans spins then powers down then powers up again about 5 seconds later only to power down again and it keeps repeating its self.
Yup had that happen before, and with the H70 installed I couldn't even see if I had connected the 8-pin connector or not. Further inspection prooved my suspicions right so I had to uninstall the fans and rad...plugged in the 8-pin connector and problem solved.;)
Looking at what you have previously done, it's either a dodgy mobo, or a dodgy BIOS flash. Did you just buy the motherboard, or did it work before you did the flash?
