I disagree with almost all of this, sorry. Fan headers aren't current-controlled, they're either voltage-controlled or a PWM signal is varied. Current is drawn not pushed. Current is shared, but two fans will present half the resistance and so draw double the current from a given voltage. Half of double the current is, yes, the same current per fan as a single fan on its own.
You're overthinking this. Maybe you've had fans which have a high starting voltage.
