- 23 Sep 2009
Exhibit 1:
VW Golf GTD £24650 (170hp)
VW Golf GTi £25320 (211hp)
Wouldn't you compare to the 1.4TSI GT 160PS which costs £21325?
Exhibit 1:
However, not all like-for-like cars follow this trend. Lets look at some alternative vehicles with various spec levels:
Exhibit 1:
Exhibit 2:
Audi TT quattro Roadster Tdi Sport S-Tronic £29020 (170hp)
Audi TT quattro Roadster TFSI Sport S-Tronic £29240 (211hp)
(unable to compare the diesel with the cheaper 160hp 1.8 petrol as they don't do the petrol in 4wd, or the diesel in 2wd according to the configurator)
Exhibit 3:
BMW 320d M Sport saloon £29895 (184hp)
BMW 320i M Sport saloon £27780 (170hp)
Quite a big increase here - possibly to maximise the profit from fleet purchases?
Exhibit 4:
Honda Civic SE 2.2 i-DTEC (Diesel) Manual £20,095 (150hp)
Honda Civic 1.8 i-VTEC (Petrol) Manual £17,995 (142hp)
Quite a big increase on the diesel.
and then on top you have the maintenance of the ignition system which is always going to be more complicated on a petrol.
nanospider said:Wouldn't you compare to the 1.4TSI GT 160PS which costs £21325?
[TW]Fox;21482242 said:You mean lets look a load of cars which are not like for like?
The GTD doesn't have the electronic XDS system either. It's definitely a case of sporty vs practicality.I don't see why a Golf GTD is not simply a GTi with a diesel engine? Other than the engines and gearboxes, which other components are different? Comparing the 160bhp 1.4 TSi GT is not valid - there is a 140hp 2.0 Tdi GT which is this cars equivalent, which at £20,930 is again cheaper than the petrol.
Well that depends on what you both consider like for like. The vehicles I compared were the same trim level and the same external appearance. The power was less on the diesels, which I quoted, and the economy is greater by a similar amount on the diesels, which I didn't quote.
Perhaps I should have included the torque figures instead, which are in favour of the diesels. "But torque doesn't determine how fast you go!" I hear you cry. Not when thrashing your vehicle down a back road perhaps - but not everyone does this. Consider the place where most miles are done - the motorway.
At 70mph in top gear, a diesel will be significantly closer to its peak power rpm compared to the petrol. I don't know about you folks, but personally I don't regularly drop a couple of gears in my petrol to get closer to my peak power every time I want to accelerate.
Lets go a little deeper into the comparison of the two Golfs which are nothing like each other:
VW Golf GTD £24650
170hp @ 4200rpm
258lbs.ft @ 1750rpm
0-60 8.1s
55.4 mpg combined
VW Golf GTi £25320
211hp @ 5300rpm
207lbs.ft @ 1700rpm
0-60 6.9s
38.7 mpg combined
So the petrol is 17% faster to 60 than the diesel. The diesel is 43% more fuel efficient than the petrol. So you are both right, I stand corrected. These two vehicles are nothing alike, the diesel is much better.
My point is, there is more to cars than performance. The majority of this forum is fascinated with power and acceleration, which is to be expected as a section of the form dedicated to motor nuts. However, in the real world most people use a car to get from A to B. Performance is not the number one aspect when selecting a car.
The diesel is much better, if you don't care about performance...
Your comparison is ridiculous.
The GTI has 40 more BHP and does 0-60 more than a second faster!
The sheer terrifying repair costs of modern diesels should be more then enough to nullify any true comparison.
The majority of new bits that have been bolted onto diesels in the past decade or so are just disasters waiting to happen.
[TW]Fox;21484588 said:Sadly this is now happening to modern petrol cars. It's nothing like as widespread yet - but in 5 years time we'll be in the same place with used petrol as we are now with used diesel.
A bit like how catalytic convertors were very expensive when they were introduced in the early 90's. Last year I got mine changed on the MR2 for £200 all in.
Priced up a cat yesterday for a 02 1.6 stilo, £1182 from main dealer.
The most terrifyingly expensive (in future) addition to most modern petrols and diesels for me is the Dual clutch transmission - people seem to gloss over how horribly expensive the eary vag dsg system has been for a lot of unfortunate individuals. Given how troublesome and expensive to fix a traditional slushbox can be I dread to think what 15 year old dsg type systems will be like.
He works in a garage - most garages do not source their components from places like Euro Car Parts.Well done.
It's an hours work to change one and they're £160 to buy. http://www.eurocarparts.com/ecp/c/F...6c7e989ac7906bc17146aaf0dff870eeb500d4&000059
Well done.
