Fans and Cooler
30 Nov 2006
Hi guys,
Have an old media machine thats gotten a bit noisy, even worse after cleaning the dust from fans!
Its an Asus AT3N7A board, can i change the fan on the cooler? Or maybe better just to put on a new cooler?
https://www.cnet.com/products/asus-...i-itx-intel-atom-330-nvidia-ion-series/specs/
The case is an Antec ISK 300
http://store.antec.com/isk-series/isk300-150.html
Accoridng to the link is has a 80mm TriCool™ fan, can I replace this with a normal 80mm case fan such as a Noctua NF-R8 1800RPM 80mm Case Fan?
TIA
Al
Hi,
Its against the forum rules to include links to other stores so I would edit your post if I was you.
As for your question... Are you after a CPU Cooler?
