Hi all
I have a z390 aorus master motherboard, and have 9 cooler master 120mm sickleflow fans. (3 pin)
I am using a antec 360mm aio cooler on the cpu, that has a power plug, and another that connects to a fan/pump header on the mb
I have 2x 3 way fan splitters, and 4x 2 way splitters that I can use if needed.
5 x fans are on the aio in a push/pull (front as air in case)
4 x fans as exit (3 top, 1 rear)
I would like the cpu/bios to control the fans with my own fan curve.
What would be the best way to connect them all up to the motherboard please?
many thanks
ian
many thanks
ian
