- 13 Aug 2004
- England
ATIorNvidia said:but what is the actual difference of it
One side has pins, on has holes to accomadate those pins.
ATIorNvidia said:... theres nothing i can se to work out
squiffy said:Get hold of a mains plug, insert into the wall socket. Whilst going "yes yes yes!![]()
You do know the differenced between a male and female?
3 pin connect to the motherboard, 4 pin molex connect to psu. For lower speed/lower current fans and if you want to control speed, get 3 pin. For case fans and other high speed/high current fans that'll stay at 100% go for 4 pin molex.
