So I apologise for what is going to be a dumb question.
Finally gotten around to fitting my WC loop over the weekend and it passed the leak test.
Turned it on this morning and on the GPU the temps are fantastic, not going over 50c on the hotspot.
The CPU seems a little off. Just browsing the internet it want to got from 25/26 to 60 in an up and down manner, which keeps setting the PWN fans (all 6) to spin really quickly for short bursts.
How do people normally deal with this behaviour, I assume its because I'm on a stock 5800X and it's AMD doing it's thing.
However in cinebench the temp ends up at about 73 under load but the pc sounds like a jet engine.
The loop is 2 x 360 rads, so there should be enough headroom for the CPU and GPU.
My assumption here is that I'll need to do a manual fan curve and ditch the PWM logic?
