The Corsair SP/AF120 arrived today and I've set them up inside the Zalman Z9 Plus case but not sure if I've set them up correctly as exhausts and intake which will help airflow,
Two top fans of the case,
Back fan,
Front fan,
Bottom fan,
Also on the other side of the CPU heatsink, do I setup the fan the same as this side?
Back fan,
Front fan,
Bottom fan,
) the fans themselves and feeling the way the air is being blown ...ie i have the front fan sucking air in through the front...and the top two fans blowing air out of the case and the same with the fan at the back ( blowing out
