i need help finding fans to replace my phanktek cooler fans, as there to loud even at 800rpm 140mm
this is the cooler/fans
http://media.bestofmicro.com/0/Q/325322/original/phanteks_ph-tc14pe_install-3.jpg
only trouble is im not sure if you can take them black things away from the current fans see the picture the metal bars go through the black gromets? to hold them in place.
what fans do you recommend? ideally want <19db lower noise the better
