FAO Simon or any Rover Turbo Owners
22 Dec 2002
Minehead
My friend has a rover 220 turbo and is wondering what the maximum safe boost to run through the engine is. He has a bleed valve and its currently boosting at around 6psi. How much more can he put through it with a standard engine without it blowing up?
Cheers for any help :)
The general agreement amongst the rover lot is 12 psi max, although bleed valves have issues with spiking. I'd recommend getting a boost control valve such as a GBE.
Just be Steady in first etc as the torque will kill the box with the standard boost control valve being bi-passed, due getting all the power in one lump instead of modulated across the rev range as standard
He has taken it to 12 and slightly higher I think but he's running it at 6 because he doesn't want to break it. I've not been out in it but apparently its quite a rapid car, certainly compared to his 220 coupe :)
Yup, 12psi (mines set to 11) max, for the gearbox's sake really. And as said be gentle in 1st gear, and head on over to http://www.gb-ent.com/ and order a GBE boost valve mk2 (GBE Mk2A Mechanical Boost Controller - easier to adjust) and a boost guage. The bleed valves are a bit dodgy.
Do they chew through gearbox's when you up the boost on them? I'm not too sure on mileage etc of this one but he's keen to look after it and hoping it will last him a while :)
as said up the boost to 12 psi and then start saving for a gearbox rebuild with steel cage bearings!! :D
Hi,
As mentioned 12psi is the max safe. I ran 13psi on a bigger turbo and intercooler without problems. The limit of the pistons is hot heat but infact the ring lands. Make too much power and the ring lands simply crack. (Over about 240lb/ft I reckon from experience) or of course too early timing.
12psi and no booting it in first around corners should help the box last. Gearbox is only really rated at 174lb.ft.
I've been running well over standard power for a long time and not really had any gearbox problems, even driving the car hard and doing about 20k miles a year. Coping with 250lb/ft at the moment just fine. I am using a 600ti box though which has a stronger diff, the main problem you get is the diff bearings collapsing (plastic cage) and taking the early Type A diff out and requiring a rebuild. Uprated steel caged bearings are the way forward but they tend to be a bit noisier.
Si
