Well I decided to upgrade to GG but it stalled saying not enough disk space - 126 MB short. While try to make space I deleted the HDD in VMware
Burned GG to CD to reinstall VM but got to desktop & both HDD & DVDrom busy & couldn't get Firefox to open or install OS despite several attempts
While searching for Sirius' guide I noticed that you can set VMware to read from the ISO in place of CD & this solved the problem.
Following the guide - v helpful - but why no sticky to it in the forum or don't I know where to look? - I had 2 problems:
couldn't get http link to FAH6 to work so had to download in Firefox & use Archive Manager, same with FahMon
I forgot to step to install libwxgtk2.6-dev & g++
Thanks to Uncle Fungus I found the help on the FahMon site that I needed libwxgtk2.8-devand after ./confiure and make it should be sudo make install
& that got FahMon finally working.
FAH downloaded core a2 & WU's were corrupt &/or wouldn't run & program crashed or stopped.
Finally this morning got core a1 & everything seems to be running ok.
And that is how a simple upgrade of 40 minutes turns into 6 hrs of frustration
Any feedback or help for the next time much appreciated.
& that got FahMon finally working.FAH downloaded core a2 & WU's were corrupt &/or wouldn't run & program crashed or stopped.
