Fast connections between PC's
Wonderful analogy, but: where did I tell the OP to buy a 10Gb switch to solve their problem...? Please quote it. I demonstrated that 10Gb would at least 3 times faster than 1Gb. If the OP would find 3 times faster "meaningful", that is their choice.
It is up to the OP to decide what to do; I am providing information. I already offered to automate and solve this problem in person in my first post in this thread.
But you didn’t demonstrate it would be faster in this example which is the one being discussed. We need to identify the bottle neck here before the solution, it’s literally the most basic step in fault finding. You would need a large portion of humble pie after throwing someone else’s money at 10Gb without understanding why the current workflow is at 5% of its stated capacity,, and you seem very hungry ;)
If they're wired in to a local switch, then it shouldn't be a remote connection then (that uses a VPN to connect). However, thinking about it now, could REALLY long lines be involved? (Beyond the length for the spec of the cable perhaps?)
Was also thinking 40Mb(it) per second didn't really fit any cable. But that was using 60s as an actual base line, to which OP did say 60s+ (plus), meaning it's likely more, but has seen 60s before (as best optimum transfer). So that got me thinking maybe 5 x 20Mb(it) per second connections? Especially if all devices are transferring at the same time to the core system. Which then suggests the swtich might not be a 1Gb(it) switch or has been set to 100Mb(it) rather than run at 1Gb(it).
So many possibilities here, need more info from OP.
The critical bit of your first sentence is ‘if’, and based on what has been posted, you are no more comfortable with the detail supplied than I am. I suspect op has omitted to tell us something vitally important, and that’s why they need to identify the bottleneck before choosing a next step. Without doing that, it’s just guess work as to if ripping everything out and putting 10Gb in would actually help, or still run at 40mbit because someone jumped the basic steps anyone who grasps basic principals of workflows and networks should take. I mean they could get lucky and the issue is in the sections they replace, or they could throw £££’s at it and get the same result as the person who updated it from 100mbit to 1Gb got, and leave someone else to actually diagnose/fix it. I know which person I would rather be in that example.
Op, please give us the info we need to actually help you.
Well, OP in first post did mention it's all wired into their 1Gb(it) switch, so I took that from there. But agree that the details provided leaves a lot to fill in and that's definitely not helping in locking down where a cause or problem is located at.
I'm personally most intrigued by OP's post because of the equipment gathering involved and of course how exactly that's all laid out given if the wired into a 1Gb(it) switch is true, suggesting quite a large area for the separate devices to gather data (hence the exceeded long network lines thought, especially if located across different buildings), or at least many rooms (then wired together to a central location), or different devices in a larger room (attic perhaps?).
