Fastest laptop drive ?
1 Nov 2004
What is considered to be the fastest laptop drive ?
I did check google but i got conflicting results on benchmarks and reviews.
Thanks
Tomshardware had the samsung spinpoint m6 s the fastest but thats only a 5400rpm drive ?
Solid State Drives are easily the fastest out there but cost a lot and their capacity is very small.
New gen sata 5400rpm 2.5" drives are pretty much on par with average sata 7200rpm 3.5" desktop drives! spindle speed is only half the story :)
Only due to Perp/Recording.
you can get 7200rpm HDD's for lappys that will blow away the 5400rpm's.
I believe there was a 15k one a while ago announced, not sure it came out.
regardless of pmr, 5400 drives like the sammy m6 have faster read/write speeds than most 7,200 drives. It even has a faster Read transfer rate than the hitachi 7k200 which is pretty much the fastest 7200 laptop drive around.
" Seagate 15K 2.5"inch Hard Drive
17/01/2007, Cnet News
Seagate has launched a new Savvio 15K HDD which spins at 15000 rpm meaning faster drive for data access useful for Servers and RAID systems. This is compared to Desktop hard drives which currently average 7500rpm or Laptop Notebook drives at 5400rpm or 4800rpm."
Think its SCSI not 100% sure if avail in others.
No link as read through Google, think source is Cnet in 2007.
The only way a HDD can be faster than another (apples verus apples not 5yr old gen v new gen) is the RPM (Spindle Speed) or the Seek (arm moving faster across Platters) or the use of Perp/Recording.
the savvio 15k drives are not at all aimed at the laptop market though, Im sure the op is not interested in a scsi drive.
I still much prefer my samsung m6 5400, its definitely faster than my old momentus 7200 in my Dell C2D system running windows Vista. I haven’t tried hitachi's 7k200 drive but on paper the sammy m6 is still faster, uses less power and comparing my old momentus 7200 to it is still probably slightly quieter in operation.
Asking the same question, is there any update?
I'm currently using a Seagate Momentus 7200.2 (160Gb) and I want to upgrade - I want the fastest (non SSD) available - which is that ATM? I can't find any benchmarks covering the latest offerings.
Can you post some benchmarks of it ic0n please? I want to compare it to my older WD 320 blue model!
Same here, both my wd blue and sammy m6 are super fast for 5400 laptop drives. I would like to see some comparison tests against these new gen 7200 2.5" drives
there was a post on here to a review of the black comparing it 2 ssd drives and it came in just after them everytime will see if i can find it
If someone has a faster drive pls post the HDTUNE graph for comparison - I am wondering whether to get an SSD or a bigger/faster sata drive for my laptop!
"7200rpm HDD's for lappys that will blow away the 5400rpm's"
I would just like to point out a couple of things, firstly 2.5" Hard disks are not just for lap-tops as there is plenty of people using then in normal desktops for either their low power consumption and generally being cool n quiet.
Secondly outside of silly benchmarks and very firmly in the *Real-World* the 5,400rpm drives are extremely nippy, especially the newer SATA-II disks that feature NCQ.
As a consumer and owner of a big ePeen I was drawn at first to the 7,200rpm 2.5" drives, I have used 7,200rpm 3.5" drives for years so it just seemed a good idea, however the whole reason I wanted to jump on the 2.5" bandwagon was to lower the power useage of my computer. After readin through dozens of datasheets I could see the slower drives had a slight advantage in the power consumption department so I went for a pair Of SATA 250GB SEAGATE Momentus 5400.4 and I have to say I am chuffed.
I cannot tell the speed difference when using my PC (compared to 3.5" 7,200rpm disks) and I dare say neither could any of you if you weren't allowed to run HDtach or similar benchies.
Bottom line, listen to what people have to say but be aware that some of them give good advice while others give bad advice . . .
Most disks are fast enough for us, now its time to pay attention to the power usaged, especially if you are going to be running them in a laptop! :cool:
