I have a new i7 IB PC and a 2011 Macbook Air (1.8GHz i5, 4GB RAM, 128GB SSD, SD card reader, USB2, Wifi).
I play Football Manager and would like to play on both machines, the save game file is about 1GB big and there are 10 of them (automatically saves every game week and keeps the previous 9 weeks worth as well).
I basically want the quickest way to be able read/write to a portable storage device that both the PC and Mac will read.
I tried popping the files onto a 16GB Class4 SD card but the load and save game time went from about 15 seconds normally up to about 10-15minutes, can easily do a week in game every 15 minutes so it was unplayable basically.
Tried having the files on my PC and loading them over Wifi but that seemed as slow, although the network was busy.
Ideally the files need to be on a portable drive as I often take the MBA out and want to be able to play on the go when I don't have internet. The MBA doesn't have USB3, only USB2.
The PC has the following connections:
USB2
USB3
Wifi
Ethernet
eSATA
(Motherboard)
The MBA has the following connections;
USB2
Wifi
Thunderbolt
Firewire
SD Card
tl:dr - fastest portable device that would store about 10GB of data and be readable on a PC and MBA.
USB2
USB3
Wifi
Ethernet
eSATA
(Motherboard)
USB2
Wifi
Thunderbolt
Firewire
SD Card
Unless you can get one with USB and eSata.
