4 Nov 2006 at 16:34 #1 knowlesy knowlesy Soldato Joined 6 Jan 2006 Posts 4,663 Location Newcastle how do i convert fat32 to ntfs on an extrernal drive .... WITHOUT... formatting.... ?
4 Nov 2006 at 16:37 #2 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA Umm, that's what formatting is. It sets the format for storing bits on the disk. EDIT: Do you mean that you don't want to lose your data when you change the data format?
4 Nov 2006 at 16:41 #3 knowlesy knowlesy Soldato OP Joined 6 Jan 2006 Posts 4,663 Location Newcastle yes...... ive tried using cmd and typing " h: /fs:ntfs" but it then asks for a volume of drive h: ????
4 Nov 2006 at 16:50 #4 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA At the Windows command-line type vol C: to get the volume label. Once you've got that type convert c: /fs:ntfs to convert the file system. I'd back up my data if I was converting the FS. Though it usually works I'd hate to see you lose any important data.
4 Nov 2006 at 16:52 #5 knowlesy knowlesy Soldato OP Joined 6 Jan 2006 Posts 4,663 Location Newcastle thanks dude ill try now..... its just a 250gb external all my info is on my pc just bought this for a backup..... EDIT: wehey its doing it !!!!! EDIT: DONE w00t!!!! thanks dude =D Last edited: 4 Nov 2006
4 Nov 2006 at 16:55 #6 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA Why do you need to convert the file system? fat32 is far more portable than NTFS.
4 Nov 2006 at 16:58 #7 knowlesy knowlesy Soldato OP Joined 6 Jan 2006 Posts 4,663 Location Newcastle id just prefer it, im just using it as my main store of files etc between my laptop and my pc like to back everything up etc....
4 Nov 2006 at 17:06 #8 ste_bla ste_bla Soldato Joined 9 Aug 2004 Posts 7,795 Location Milton Keynes BillytheImpaler said: Why do you need to convert the file system? fat32 is far more portable than NTFS. Click to expand... Except the 4gb file size limit
