- 7 Mar 2013
- Caistor
Hi
Yeah the MOBO worked perfect no issues at all, no faults at all. My best advice is to double check it once you receive it back
The case has been replaced for you with a brand new one
Thanks
Bailey
Hi,
I have already double checked the motherboard and that is why I feedback on the testing procedure.
The current max outpht of the cpu fan header is indeed around 50%, as evident in the BIOS. And the fan does spin up to 100% when connected to an Aquaero 5 LT.
Thanks for the replacement order, that is really appreciated Bailey.
