Just out of interest
@bazzabear, did your dad sign any paperwork at the time, acknowledging that he was responsible for the damage caused, and that he would be liable for all costs incurred to repair the damage?
He doesn't have to. It will be covered by the general law that asserts the property owner (or anyone they hire) as responsible for damage to third party assets.
Why is it so different from water, where if it's not yours or is shared it's the water companies problem.
Not quite how it works.
Maintenance on shared connections, or the lack of it resulting in degredation and/or failure,
is the water company's issue... but actual third party damage is usually the problem of that third party. The water company
will likely fix it, but the third party will
pay for it.
And I thought there was a minimum depth much like water.
There is, but it depends on circumstances and only applies to new installations from a certain date.
There is no way most of that could be applied to older city assets, for example.
If the pipe was so close to the surface i'd expect it to have been marked with tape, 4" is totally and utterly taking the P.
"However, these depths are
only a guide and
should not be relied on when carrying out work near gas services or mains. For example, road levelling, landscaping and
other changes to ground conditions after a gas main or service has been laid (
often decades before) can result in the depth of the ground cover changing over time. Also, gas pipes may have projections coming from them, such as valves, which are not shown on plans and may have less depth of cover than the pipe."
Ground movement is a
big factor in buried services. Most degredation to our assets occurs due to this, largely driven by vehicle traffic.
Also I wouldn't pay it. Nothing will come of it they'll just give up trying to collect the invoice in the end.
No, they'll just pass it on to debt recovery services.
They'll first try everything else they can, from payment plans to reduced billing, but they will NOT simply let it go, especially with regulators tightening spending.
