Fault testing
24 Jun 2004
Carnoustie
Afternoon ,
Having some issues recently ,mostly regarding crashing during gameplay ,
I've also noticed like a ticking coming from my computer ,which is very intermittent
Im not completely sure its coming from the Psu unit [is there any way of fault testing ] preferably software run
Ive tested my ssd drives and they seem to be fine ,I just think possibly the PSU when under load ?
System is i7 8700k ,20180ti,16gb 3600 and Corsair TX 550M
Any help appreciated please
The psu may be at it's limit as a 2080ti can draw 300w by itself, even more if overclocking. Depending on the version of the TX-M you have you either have 540w on the 12v rail with the bronze version or 516w on the 12v rail with the gold version. Personally I would want at least a 750w psu to power a 2080ti plus I would be powering it from two seperate pci-e leads and not a single lead with a pair of daisy chained connectors.
Ok ill go look for a 750 ,could you recommend one ,there not cheap lately
▷ Super Flower Leadex III ARGB 750W 80 PLUS Gol… | OcUK (overclockers.co.uk) ??
Im since also wondering if its something also to do with the Firmstorm software i have installed [this has a overclock scanner on it ]
Could this also have the Graphics card crashing out during gameplay ?
Ive purchased the Phantecs first see if that sorts it out
