Easy to repair.
Really, any links?
Really, any links?
xclamp replacement. I've fixed a load of them and all but one is still going.
The xclamp fix looks sensible, as long as its not been run for too long after it went faulty.
Yes but it's pointless unless you also replace the x-clamp.
If MS seal is still intact and console is not registered with MS before then abviously you can send it to MS for repair.
I bought one 2 weeks ago from bay for £35(just a console nothing else).I was lucky becasue that xbox360 never been registered with MS before so i send it MS got it back repaired yesterday all fixed.
