hi
i have a main pc running a 60 gig agility 3 SSD for windows and 1tb for storage - sata 3 normal drive.
i have a am3+ gigabyte mobo with a FX4100 processor and 8 gig of corsair ram.
when i select AHCI mode in bios, it will not get past the windows start screen without crashing. select ide and fine, starts and runs fine. not sure whats happening there.
2nd 120 gig agility 3. not sure if its faulty on a 2nd machine. random crashes in windows and seems to take ages loading windows initially - the bit when the bios goes and it says loading operating system..........
on the first system, it flashes up, goes and loads windows.
on the 2nd 120 gig drive it comes up and then seems to load............................................................. - this takes about 30 seconds to a minute - then boot into windows and then randomly crashes. i ran sandbox to update firmware which failed, probably due to ahci mode not working. smart data showed this:
SMART READ DATA
ModelNumber : OCZ-AGILITY3
Serial Number : OCZ-
WWN : 5-e8-3a-97 efe3e6992
Revision: 10
Attributes List
1: SSD Raw Read Error Rate Normalized Rate: 87 total ECC and RAISE errors
5: SSD Retired Block Count Reserve blocks remaining: 100%
9: SSD Power-On Hours Total hours power on: 115
12: SSD Power Cycle Count Count of power on/off cycles: 105
171: SSD Program Fail Count Total number of Flash program operation failures: 0
172: SSD Erase Fail Count Total number of Flash erase operation failures: 0
174: SSD Unexpected power loss count Total number of unexpected power loss: 7
177: SSD Wear Range Delta Delta between most-worn and least-worn Flash blocks: 0
181: SSD Program Fail Count Total number of Flash program operation failures: 0
182: SSD Erase Fail Count Total number of Flash erase operation failures: 0
187: SSD Reported Uncorrectable Errors Uncorrectable RAISE errors reported to the host for all data access: 0
194: SSD Temperature Monitoring Current: 30 High: 30 Low: 30
195: SSD ECC On-the-fly Count Normalized Rate: 120
196: SSD Reallocation Event Count Total number of reallocated Flash blocks: 0
201: SSD Uncorrectable Soft Read Error Rate Normalized Rate: 120
204: SSD Soft ECC Correction Rate (RAISE) Normalized Rate: 120
230: SSD Life Curve Status Current state of drive operation based upon the Life Curve: 100
231: SSD Life Left Approximate SDD life Remaining: 100%
241: SSD Lifetime writes from host lifetime writes 180 GB
242: SSD Lifetime reads from host lifetime reads 264 GB
is this a faulty drive?
the first(60 gig ssd) is fine. just not when ahci is selected in bios.
SMART READ DATA
Revision: 10
Attributes List
