OK so here goes I will try to explain the issue as clear as I can.
Relatively new build
The Rig:
GA-Z87X-OC, 4770k @ 3.5Ghz, 16GB (2x8GB) G.Skill 2133, 256 Samsung 840 Pro SSD, Asus Matrix 280X PE, Antec 750w HCG, Corsair Hydro H105, and Windows 8.1 64 Bit. Running at stock (did slowly OC the rig to 4.2Ghz but this issue kept popping up so back to stock).
The Issue:
Occasionally it will boot really slowly, and rarely it just wont post but will boot with a cycle - off/on. Used to have a 3TB HDD which caused super long load times when booting off the SSD but that drive has been moved to a media PC.
The secondary issue is on cold or warm boots - and at random when I get to the desktop and then load any game my FPS drops to 3 FPS when I usually get 70-73 FPS happens in all games and the only way to fix it is to reboot until the issue is gone - sometimes takes 1-3 boots. The comp then runs perfectly. If I get a slow boot I know I'm going to get low frames, sometimes it seems like it boots fast then
Basic Tests:
-Complete system reset and re-install
-Tried checking CPU parameters with OCCT and comparing the values between normal boot and a low FPS issue - No obvious changes in values.
-Tried checking GPU parameters with GPU Tweak and MSI Kombustor comparing the values between normal boot and a low FPS issue - No obvious changes in values.
-Ram values remain the same, swapped ram around no changes
All the voltages look very similar if not identical so I am not sure what else to do. I may have to run the GFX in the other PC and see if its the GFX card or stick an old gfx card in and see what happens. I'm thinking its the mobo or the gfx card. I am really busy with work ATM plus trying to sort other stuff out thought I would ask to get some direction in how to best troubleshoot this issue.
So does anyone have any suggestions? is there any software that can track all the hardware settings and values and log dump it without having to run 5 or more separate software and try and get the to log dump. If there is something that can track voltages and clock settings/timings (I have lost track of the countless software apps I have tried to try and troubleshoot this issue. This is the only issue I have, when its running well I don't have any problems.
Anyway if you need further info just ask... Oh and I did replace the PSU had a old corsair 650 HX and thought maybe it was a power issue but the new PSU didn't solve anything. Any help is much appreciated
Kordi
The Rig:
The Issue:
Basic Tests:
Kordi
